| Application | PLAXIS 3D |
| Version | PLAXIS 3D CONNECT Edition V20 |
| Date created | 25 October 2018 |
| Date modified | 2 February 2021 |
This following demonstration video intends to illustrate the use of movement functions to simulate a train passing through a rail track over an embankment.
When using PLAXIS 3D Ultimate license, it is possible to assign movement functions to a given load to simulate load movements along the model (e.g. train moving over an embankment).
At the end of the video, the results and impact of train-induced vibrations are shown in an animation.
