| Version: | V8i | ||
| Area: | Print/Plot | ||
| Subarea: | N\A |
When selecting File > Print User is getting a 'command not defined' error.
The MS_PLTR variable was defined to a .plt file that no longer existed or no longer in the location being defined.
Define it to the default location and used printer.plt. This fixed the error.
| Original Author: | Mark Marrero |
