| Version: | V8i, CONNECT | ||
| Area: | Print/Plot | ||
| Subarea: | N\A |
Is the Print Organizer also available from within MicroStation PowerDraft?
Yes, the Print Organizer is part of MicroStation PowerDraft.
In MicroStation PowerDraft CONNECT Edition it can be located under the menu > General > Output > Print Organizer or > File > Print.
| Original Author: | Frank Reimann |
