| Version: | V8i | ||
| Area: | Print/Plot | ||
| Subarea: | N\A |
Is there a configuration variables to override the software's default print definition name expression?
The variable is:
MS_PLT_DEFAULT_PRINTDEF_NAME_EXPRESSION
it overrides the software's default print definition name expression.
| Original Author: | Edwin Yepes |
