| Version: | 08.11.09.459 | ||
| Area: | Printing | ||
| Subarea: | N\A |
Is there a PDF size limit of 200 X 200 inches when using MicroStation v8i printing?
There was a size limit of 200 x 200 inches in pre-v8i versions of MicroStation due to Adobe limitations.
However, in MicroStation V8i the pdf.pltcfg driver can be modified to create larger than 200 x 200 inch PDF files.
To modify the size - edit the PDF Printer Driver Configuration - under Base Properties -> Driver Properties -> set the PDF version to Acrobat 8 (PDF 1.7) .
| Original Author: | Mark Marrero |
