| Version: | All | ||
| Area: | Print/Plot | ||
| Subarea: | General |
In the Xerox 7535 Workcenter -> Printing Preferences -> color option = Black and White (B/W).
If printing via MicroStation (SELECTserie 2) he uses the following workflow to get a color print:
1. Go to the menu File > Print
2. In the Print Dialog the 'Color' option is set to 'True Color'
3. Remaining in Print Dialog, go to the menu File > Select Windows Printer
4. Select/highlight the printer and click on Preferences
5. In the Printing Preferences dialog, the tab to control the Color is found
6. Color option is set and file can be printed
Is there a way to change the color option from B/W to color within MicroStation (*.pltcfg, print style)?
MicroStation has no control of the Color Options settings in the Printing Preferences of this device.
| Original Author: | Frank Reimann |
