| Version: | 08.11.07.443 | ||
| Area: | Printing | ||
| Subarea: | N\A |
Printing line styles to a KIP 7700 and they are plotting solid when using printer.pltcfg.
This issue was narrowed down to being an issue only on the KIP 7700.
All other printing devices gave the correct results and the PDF.pltcfg produced the correct line styles in PDF.
Steps to Resolve
Set the "Output Format" in Printing Prefences for the Windows print queue to KIPScript.
Set the "Output Format" in Printing Defaults for the Windows print queue to KIPScript.
| Original Author: | Van Kendall |
