| Version: | All | ||
| Area: | Printing | ||
| Subarea: | N\A |
Print Preview is not showing style edits made using the Line Styles tab of the printer driver configuration editor unless rasterized is checked.
For performance reasons, the Print dialog preview does not attempt to reproduce accurate on/off run lengths in the preview window for non-rasterized mode.
Line styles are mapped to fixed Windows GDI line patterns.
| Original Author: | Todd Combs |
