Discover ParaView post-processing environment for PLAXIS 3D calculation (Tech Preview)
Application PLAXIS 3D
Version Technology Preview
PLAXIS 3D CONNECT Edition Update 4
Date created 08 October 2020
Date modified 08 October 2020
With the release of PLAXIS 3D CONNECT Edition Update 4 (20.04), new options for advanced post-processing are being offered with the PLAXIS Output software now capable of exporting all the results to a ParaView file format. On this page, you will find a list of short demo videos introducing the use of ParaView for post-processing PLAXIS 2D and 3D model results..
Introduction: How to export PLAXIS 3D output results into ParaView
Performing PLAXIS geometry/mesh object selection interactively in ParaView
Fundamentals of PLAXIS model element selection
Alternatives techniques for PLAXIS model element selection and introduction to grouping
Back to top
Advanced PLAXIS model results rendering
Introduction to advanced model result rendering
How to superimpose animated plots and curves in one view in ParaView
How to superimpose curves over different phases in ParaView
Extrude 2D axisymmetric results in 3D space
Back to top
Some scripting examples
Easily generate Python scripts using Python command tracing option of ParaView
Automation of curves superposition over multiples phases made easy
Back to top
Working with large PLAXIS model data
Back to top
Resources
ParaView is an open-source, multi-platform data analysis and visualization application. Website: https://www.paraview.org/
