| Version | PLAXIS 2D CONNECT Edition V20 Update 3 and later PLAXIS 3D CONNECT Edition V20 Update 3 and later |
| Date created | 24 July 2020 |
| Date modified | 05 October 2020 |
Following requests from our users, we released a new tool in PLAXIS 2D/3D CONNECT Edition V20 Update 3 (20.03) to easily queue up all your PLAXIS 2D and PLAXIS 3D calculations. Now, before leaving the office, you can set up a list of PLAXIS project files to be calculated and let them run sequentially over-night! When the calculation is done, you can directly check the Input model or jump to the results in PLAXIS Output.
