| Version | PLAXIS 2D CONNECT Edition V20 Update 3 PLAXIS 3D CONNECT Edition V20 Update 3 |
| Date created | 01 July 2020 |
| Date modified | 15 January 2021 |
In the past years, users asked us to help them write the correct command or use the correct PLAXIS object name in the command line so they could work more efficiently, make fewer mistakes and save time. Now you can do so by enabling this option from the Options menu option in PLAXIS 2D/3D Input.
We are happy to have it now available as a full feature available for all our Geotechnical SELECT Entitlement users!
