| Application | PLAXIS 3D |
| Version | PLAXIS 3D CONNECT Edition V20 Update 3 |
| Date created | 06 August 2020 |
| Date modified | 06 August 2020 |
In PLAXIS 3D, we have a tool that can help you to easily create shapes for your geotechnical analysis. It offers more control and is easier to use.
Since PLAXIS 3D CONNECT Edition V20 Update 3 (July 2020), the Polycurve designer includes new functionality for easy creation of circular and square poly curves for quick generation of geometric shapes to be used for burried pipes, simple tunnels and piles.
In this video, we will use the Polycurve designer for the creation of:
