| Version: | All | ||
| Area: | Print/Plot | ||
| Subarea: | N\A |
Need to control levels for plotting. User wants to turn off certain levels on the plot and also control the display of these levels in the design file.
Recommend you use Level Manager for turning off the levels on the plot (Plot option under Properties). This will leave the levels on in the design file.
Key-ins can be used to set Levels Plot Off/On
level set plot OFF "Level 36" "Level 5" "Level 24"
level set plot ON "Level 36" "Level 5" "Level 24"
| Original Author: | Johnny Kendall |
