| Version: | All | ||
| Area: | Printing | ||
| Subarea: | N\A |
This example should show how to open the print dialog box with the following predefined settings using the function keys Ctrl+F2
Printer driver = pdf.pltcfg
Paper = ISO A2
Option Rasterized ON
Color = Grayscale
Pen Table = Projekt_1.tbl
Open the function keys dialog box
MicroStation -> Workspace -> Function Keys … ->
Select the key Ctrl+F2 and enter in the Action field the following Print Dialog Key-ins:
print dialog; print driver pdf.pltcfg; print papername ISO A2; print rasterized ON; print colormode grayscale; print pentable attach c:\Pen_Table\Project_1.tbl
ok
Now you can open the print dialog box with the predefined settings using the function key Ctrl+F2.
You can find information about the Print Dialog Key-ins in MicroStation Help
Contents -> Working with complete Designs -> Printing -> Print Dialog
| Original Author: | Frank Reimann |
