| Version: | All | ||
| Area: | Print/Plot | ||
| Subarea: | N\A |
User is printing the same .pdf file generated in MicroStation to different plotters.
On some plotters the file plots correctly, on others, the shaded areas and vertex lines are distorted.
Open the .pdf file and select File > Print > Advanced
check "Print As Image" button, then print file.
| Original Author: | Marion Powell |
