| Application | PLAXIS 2D |
| Version | PLAXIS 2D |
| Original Author | J. Sopko |
| Date created | 23 March 2016 |
| Date modified | 12 July 2018 |
Plaxis bv was contracted by Moretrench in the USA to provide assistance in setting-up 2D finite element models for the analysis of time-dependent temperature development in frozen ground with flowing water. Thanks to PLAXIS Expert Services, valuable results have been obtained in terms of evaluating the time required to obtain a satisfactory frozen wall thickness depending on the water flow intensity generated by neighboring dewatering.
Temperature distribution (left) and water flow (right) around freezing pipes
