| Application | PLAXIS 2D LE PLAXIS 3D LE PLAXIS Designer |
| Version | PLAXIS 2D LE CONNECT Edition V21 PLAXIS 3D LE CONNECT Edition V21 PLAXIS Designer CONNECT Edition V21 |
| Date created | 02 February 2021 |
| Date modified | 02 February 2021 |
Working remotely is easy thanks to CONNECT Licensing!
If it does not work out, reach out to:
Service Request Manager for any technical question and support. Our technical experts are ready to help: https://apps.bentley.com/srmanager/ProductSupport
Bentley Communities: this WIKI and the Forum
