| Version(s): | 08.11.09.292 | ||
| Area: | Printing | ||
| Subarea: | |||
| Original Author: | Dawn Clark, Bentley Technical Support Group | ||
How do I set the Raster Quality using a Print dialog key-in?
Use the following key-in:
Print rasopt quality [1-100]
The existing command "Print quality [1-100]" is an obsolete key-in that was used for HP-GL/2 quality.
