| Version: | 08.11.07.443 | ||
| Area: | Printing | ||
| Subarea: | N\A |
How can I print directly to the printer using Bentley Printer drivers as HPGL2.PLTCFG or HPGLRTL.PLTCFG
There are a few methods to do so:
1) UNC Path.
Use the unc path of the shared printer.
In Print Dialog select Edit Printer Driver Configuration.
Under tab Base Properties – Default Print File Name – File Name
fill in printers UNC path
The format of the UNC path is \\<printer server name>\<Printer share name>
2) Use LPR port.
Before doing so: Make sure LPR Port Monitor is enabled.
LPR can be enabled in Windows 7 under Control Panel – Programs and features – Windows Features.
fill in printers TCP/IP Address.
The Print dialog sends the print directly to the printer rather than create a plot file.
| Original Author: | Evert de Jong |
