| Version(s): | N\A | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Mark Marrero, Bentley Technical Support Group | ||
What is the search path Print Organizer uses to locate dgn files?
Print Organizer uses MS_DEF to locate design files if they are not found using path in the pset.
