| Version(s): | N\A | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Beverly Dawn Gentry, Bentley Technical Support Group | ||
Print Organizer is not automatically updating the Title Block information when printing.
The worker MicroStation must be opened using Read/Write on the design file. When printing from Print Organizer, look in the Edit Preferences, and make sure "Open design files in read-only mode" is not checked.
