| Version(s): | 08.11.09.357 | ||
| Area: | N/A | ||
| Subarea: | |||
| Original Author: | Todd Combs, Bentley Technical Support Group | ||
Receiving the following Print Organizer error when attempting to create a single multiple page PDF with pdf.pltcfg. Separate PDF files create without a failure:
PDFDriver.OpenPdfFile exception (PDDocOpen)
Batch Print produces the following error: Executed print documentset end (failed, error=248)
If using MS_RASTER_CFILE_FOLDER for Raster Manager caching, confirm MS_RASTER_CFILE_FOLDER is set to a valid value. The Print Organizer print definitions do not require raster attachments to experience the failure.
