| Version(s): | 08.11.09.459 | ||
| Area: | Printing | ||
| Subarea: | |||
| Original Author: | Todd Combs, Bentley Technical Support Group | ||
When printing to PDF with Georeferencing enabled the following error displays in the Message Center:
“The coordinates are outside the valid range of the GCS”
The error indicates the current Geographic Coordinate System selected for the design file is inappropriate for the design location. The solution is to select the appropriate Geographic Coordinate System for the design location.
