| Version(s): | 08.11.09.459 | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
| Original Author: | Mark Marrero, Bentley Technical Support Group | ||
Pscript.pltcfg .pro files not getting copied out of ProjectWise.
MS_PROLOG = PW path\*.pro
Create a new variable named MS_PROLOG in the managed workspace and point it to the ProjectWise folder containing the pscript.pltcfg and .pro files. This should force ProjectWise to copy all the files to the working dms folder.
