| Version(s): | 08.11.09.357 | ||
| Area: | Printing | ||
| Subarea: | |||
| Original Author: | Todd Combs, Bentley Technical Support Group | ||
When printing with raster attachments the following error displays:
QVision
32-bit compilation: 4 byte QvIDs
Error - Exceeded max glib matrix cache usage of 256
Decreasing the Raster Quality Factor in the Print dialog from 100 to 75 or more if needed.
Error message can be ignored - print should work regardless
Check Grahpics card memory - smaller older cards should be the only time the message is displayed (256 MB card for example)
