| Version(s): | 08.09.03.57 | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Marion Powell, Bentley Technical Support Group | ||
Raster does not display in Print Preview. User has an attached Raster Manager image in the design file which is not displaying in the MicroStation Print menu Preview window and does not plot to paper.
Check the plot column in Level Manager - In MicroStation XM, raster images are now associated with levels. Therefore the level that the raster image is pointing to must have the plot column checked in order for the raster image to display in the Preview pane as well as plot. If the plot column for that particular level is not checked, the Preview pane will not display the raster image, nor will it plot it to paper.
