| Version(s): | N\A | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Todd Combs, Bentley Technical Support Group | ||
Raster Manager attached Tiff files are printing with random gray shapes. The gray shapes are not consistent in size or location between plots.
Set "Optimize Color Depth" = False in the pltcfg, the default value is True.
