| Version(s): | 08.09.04.51 | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Edwin Yepes, Bentley Technical Support Group | ||
Reference files at the top of the Update Sequence are plotting in front of files at the bottom of the sequence. How can I fix this?
Verify that your workspace configuration has the following variable:
MS_LEGACYDRAWORDER
if it does, set it to 1. Save the setting and restart MicroStation.
