| Version(s): | N\A | ||
| Area: | |||
| Subarea: | N\A | ||
| Original Author: | Frank Reimann, Bentley Technical Support Group | ||
Round pipes are displayed as square pipes in a 3D PDF file using pdf.pltcfg driver
Open MicroStation Print Dialog -> Settings -> 3D Plotting -> and set Mesh Toleranz =0.001
