| Version(s): | N/A | ||
| Area: | Printing | ||
| Subarea: | |||
| Original Author: | Mark Marrero, Bentley Technical Support Group | ||
When saving pdf's via the PDF.pltcfg plot driver the Save Print as uses the workspace variable MS_PLTFILES as the directory it opens by default to save the pdf in.
