| Version(s): | 08.11.09.459 | ||
| Area: | Printing | ||
| Subarea: | |||
| Original Author: | Mark Marrero, Bentley Technical Support Group | ||
In the MicroStation V8i SS2 print dialog, there is a key-in box for the "Origin" which shifts the design around on the selected paper size. Is there any way to set this "Origin" in the .pltcfg file?
You cannot set the origin in the .pltcfg, but it can be done in a Print Style under the the Main tab.
