Applies To | |||
Product(s): | MICROSTATION | ||
Version(s): | N\A | ||
Environment: | N\A | ||
Area: | Print/Plot | ||
Subarea: | N\A | ||
Original Author: | Frank Reimann, Bentley Technical Support Group | ||
Sheet model sizes (ISO A0, A1,A2,A3) are not honored when loading design file in print organizer using the Manually specified option -> Fence -> Prefer sheet models. Print Organizer loads the sheets and set the paper size = ANSI A
Open Print Organizer -> Edit -> Preferences -> Sheet Definition -> and select "Honor sheet layout" -> OK -> Print Organizer must be restarted before changes to preferences take effect -> OK
