| Version(s): | N\A | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Evert de Jong, Bentley Technical Support Group | ||
Text is not searchable in PDF using PDF.PLTCFG and a pen table.
This pen table does even not affect and text elements. Submitting the same print without having a pen table attached, then text is searchable in PDF file.
This is resolved in MicroStation V8i
