| Version(s): | N\A | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Frank Reimann, Bentley Technical Support Group | ||
The print border is cut (not visible) on the hardcopy
Change the units in MicroStation -> File -> Print -> Print dialog box ->Settings -> Units -> from "inches" to "mm"
