| Version(s): | 08.11.09.459 | ||
| Area: | Printing | ||
| Subarea: | N\A | ||
| Original Author: | Todd Combs, Bentley Technical Support Group | ||
When attempting to use a decimal value to define Print widths for Weight Maps and Color Maps the dialog does not accept a dot in the Print Width field. When entering a dot (period) in the Print Width field the value changes to 0 and does not accept the value you entered.
