| Version(s): | N\A | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Frank Reimann, Bentley Technical Support Group | ||
The sheet model option in the print dialog box -> General Settings -> Area is grey out.
The reason for the problem was the use of a negative sheet size definition in the file "sheetsizes.def".
