| Version: | V8i, CONNECT | ||
| Area: | Printing | ||
| Subarea: | Dialog |
I have set transparency in my design model and in my sheet model. Both are working fine.
But when I want to print, the transparency is not working, even in the print preview.
To print transparency the option "Rasterized" has to be selected in the Print dialog:
File > Print > General settings
(or Ctrl-P > General settings)
| Original Author: | Rene van den Brink |
