User received a blank print/preview and a blank paper print independent which *.pltcfg driver he use
 Product(s):MICROSTATION
 Version(s):N\A
 Environment: N\A
 Area: Print/Plot
 Subarea: N\A
 Original Author:Frank Reimann, Bentley Technical Support Group
User received a blank print/preview and a blank paper print independent which *.pltcfg driver he used and with or without using the print option "rasterized".
Go to Settings -> View Attributes -> Display style -> change Wireframe to Drahtmodell
