| Version(s): | 08.11.09.459 | ||
| Area: | Printing | ||
| Subarea: | N\A | ||
| Original Author: | Marion Powell, Bentley Technical Support Group | ||
To use Print Organizer Key-in commands to manipulate certain print definitions within an existing .pset, use the following steps:
An existing .pset (data.pset) contains the following print definitions: brake, ar1, ar2. In order to Print Preview 2 of the 3 print defintions, take the steps below from within MicroStation:
mdl load bentley.microstation.printorganizer.dll
