| Version(s): | 08.11.09.459 | ||
| Area: | Printing | ||
| Subarea: | N\A | ||
| Original Author: | Todd Combs, Bentley Technical Support Group | ||
When using pdf.pltcfg, The User wants to open Windows Explorer with the folder in which the PDF file was created. The PDF file output locations vary.
In pdf.pltcfg use explorer.exe as a post-print command with $(MS_PLTOUT)\..
