What is the correlation between the Transparency setting number displayed in the Element Output sect
 Product(s):MICROSTATION
 Version(s):N\A
 Environment: N\A
 Area: Print/Plot
 Subarea: N\A
 Original Author:Johnny Kendall, Bentley Technical Support Group
What is the correlation between the Transparency setting number displayed in the Element Output section in the pen table dialog box and what you see when you open the pen table directly with a text editor?
For example when it is set to 60 in the dialog box it displays as 153 in the actual text file.
Internally, the pen table application treats transparency as ranging from 1 to 100. Externally, the pen table file uses transparency values from 1 - 255.
The values inside the pen table are percentages of transparency.
For the example 60% of 255 is 153.
