| Version | PLAXIS CONNECT Edition V22 |
| Date created | 24 January 2022 |
| Date modified | 24 January 2022 |
| Original author | Stefanos Papavasileiou - Bentley Technical Support Group |
The PLAXIS Input offers two ways of defining a soil/rock or structural material data set:
In this article, you can find the information about defining and editing a material data set via the PLAXIS command line which is located at the bottom of the Input program.
To define any soil/rock material data set you need to use the soilmat command. A simple example of defining a Mohr-Coulomb material data set is shown below:
soilmat "Identification" "Sand" "SoilModel" "Mohr-Coulomb" "gammaUnsat" 17 "gammaSat" 20 "ERef" 13000 "nu" 0.3 "cRef" 1 "phi" 30
The syntax of the soilmat command is the following:
The soilmat command is followed by one (1) or more pairs of property name + value of the property.
The property name is always defined as a string (text within quotation marks) and a value of the property can be of various types (e.g., string, number, other PLAXIS object). For example, in the soil material data set above:
The command syntax when defining a structural material data set, such as plates, anchors, embedded beams, is the same as the one of the soil/rock material data sets.
A simple example of defining a plate material data set is shown below:
platemat "Identification" "DiaphragmWall" "MaterialType" "Elastic" "W" 10 "EA1" 7500000 "EI" 1000000
To edit a material set via the command line you can use either of the following two commands:
The set command allows changing the property value of a single property, while the setproperties allows changing multiple property values at the same time.
A few examples are shown below:
set Sand.phi 28
setproperties Sand "gammaSat" 19 "ERef" 12500.0
set DiaphragmWall.W 12.5
setproperties DiaphragmWall "W" 12.5 "EA1" 7000000.0 "StructNu" 0.2
