| Version | PLAXIS CONNECT Edition V22 |
| Date created | 24 January 2022 |
| Date modified | 24 January 2022 |
| Original author | Pedro Reis - Bentley Technical Support Group |
An improved and more versatile format for storing material data set information has been implemented with the release of PLAXIS CONNECT Edition (CE) V22.
The following video shows how you can easily convert your previous material databases to the new PLAXIS V22 database format.
The procedure described in the video to convert a material database from the previous format (.matdb) to the new format (.matXdb) is the following:
With these simple steps, you can easily convert existing material databases to the new format and start using them in the latest PLAXIS version!
