| Version | PLAXIS CONNECT Edition Version 22 |
| Date created | 24 January 2022 |
| Date modified | 24 January 2022 |
| Original author | Stefanos Papavasileiou - Bentley Technical Support Group |
In PLAXIS Input, the Model explorer displays information related to all the entities composing the model. All modifications, such as creating a new polygon or a plate, are automatically updating the Model explorer data.
Figure 1: Layout of the Model explorer in different modes: Structures Mode
An important component of any finite element analysis is the materials used to simulate the soil, rock and structural behaviour. The Model explorer also contains information about the materials used in a specific project.
The materials used in a model can be viewed in the Model explorer, under the Attribute library. You can easily expand the tree view and locate all the available materials, alphabetically ordered, and their properties as can be seen in Figures 2 and 3.
Figure 2: Materials in the Model explorer side by side with the material sets window
Figure 3: Stiffness properties of the Sand material.
Within the Model explorer, it is possible to directly configure and edit any available material property. You can simply navigate to the relevant material and expand the relevant tree. To configure or edit any material property, you can select the relevant field and use the keyboard or the mouse to provide input.
When making any change to the material properties, you will notice a command being executed in the PLAXIS command line session.
Figure 4: Editing the stiffness property of the Sand material.
Figure 5: Editing the stiffness determination of the interface of the Sand material.
For more information on the material properties, you check the details in the Command reference under Help menu.
