| Version(s): | N\A | ||
| Area: | |||
| Subarea: | N\A | ||
| Original Author: | Beverly Dawn Gentry, Bentley Technical Support Group | ||
When plotting transparent gradient fills, why do you have to use Rasterized mode for PDF output?
This is a WAD. PDF does not support partial opacity on raster data, which is how we output gradient fills. The entire view must be rasterized in order to support translucent raster.
