Applies To | |||
Product(s): | MICROSTATION | ||
Version(s): | N\A | ||
Environment: | N\A | ||
Area: | N/A | ||
Subarea: | N\A | ||
Original Author: | Frank Reimann, Bentley Technical Support Group | ||
When printing with the rasterized option to PDF from within MicroStation, the resulting rasterized tiles in the PDF file are causing grey shapes to appear over color shapes when printing to a Canon iR C2880 using the latest iR C2880/C3380 UFR II driver.These shapes are not visible when viewing the PDF.
Load the latest postscript driver will fix this problem.
