| Version(s): | N\A | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Todd Combs, Bentley Technical Support Group | ||
When selecting Print in the print dialog the "Save Print As" dialog does not open.
Make sure the Print Output Directory (MS_PLTFILES) variable is set to a single valid directory.
