| Version(s): | MicroStation V8 | ||
| Area: | |||
| Subarea: | N\A | ||
| Original Author: | Edwin Yepes, Bentley Technical Support Group | ||
When we try to open the print dialog box from the pulldown menu or from key-in we get the following error:
MDLSYSTEM_LOADMDLPROGRAM FAILED
In this instance the problem appeared to be caused by an update to Axiom software. In that If the Axiom.cfg is removed from the C:\Program Files (x86)\Bentley\MicroStation\config\appl directory it worked.
Should this be applicable in your instance, please check with Axiom support for a fix to this issue.
