| Application | PLAXIS 3D |
| Version | PLAXIS 3D AE |
| Date created | 31 August 2016 |
| Date modified | 31 August 2016 |
A small Python script was written to obtain deformation results using the Remote scripting features in the PLAXIS 3D AE Output program. The results are retrieved using Output’s getsingleresult command for a set of coordinates written in a text file. The retrieved results are stored in a separate text file.
This Python script was written for PLAXIS 3D AE in combination with Python 3.4.x
Filippo Forlani
Filippo Forlani
SGAI srl, ITALY
www.sgai.net
email: filfor @ gmail.com
Twitter @FilippoForlani
This Python script is licenced under GNU GPL 3.0
Disclaimer: This Python script is made available as a service to Plaxis users to be used in combination with a VIP licence. However, Plaxis does not accept any responsibility when using this Python script in combination with Plaxis. Hence, the user needs to validate results obtained from this script by him/herself. Plaxis does not provide support on the use of this Python script.
