| Version(s): | N\A | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Todd Combs, Bentley Technical Support Group | ||
Which printing configuration variable specifies the search path for saved MicroStation print definition (.pset and .ini) files.
MS_PRINTDEF_PATH specifies the search path for saved MicroStation print definition (.pset and .ini) files.
